MULTITOUCH ISSUE
SatishAryan
MULTITOUCH ISSUE
upto how many fingers xperia sp is supported??
Ashroft98
Enthusiast
Mine has 10 fingers supported.Probably you got your fingers all too close,try to spread out the fingers.If that dosen't solve it,re-install the app and try again.
4 REPLIES 4
Ashroft98
Enthusiast
It can support up to 10 fingers simultaneously.
SatishAryan
but my xperia sp  is supporting upto 5 fingers. tested using multitouch tester, atutut test.
Ashroft98
Enthusiast
SatishAryan
thank u for fast reply:smileyhappy:
