miro contacts problem
burt
Cannot put any phone numbers in to. Phone contacts either by importing from sim or by adding new numbers
profile.country.RO.title
_alexdon_
Try settings-apps-all-contacts and phone,force stop and clear data.Restart and check again.
alexdon
10 REPLIES 10
_alexdon_
What does it happen when you try?
alexdon
burt
When I import from sim it goes through the routine and tells me all contacts have been imported but nothing shows up in my contacts
_alexdon_
Try contacts-settings-filters,make it show you local contacts.
alexdon
burt
Won't let me do that.
_alexdon_
Why not? Could you post a picture from contact settings?
alexdon
burt
The filter settings are showing as unavailable
_alexdon_
alexdon
burt
Sorted thank you
_alexdon_
Anytime.
alexdon
