Media Go problems
rhorne9
Media Go problems
I have been using Media Go to transfer my files to my Xperia Arc S phone. Today when I tried to open the application on my computer it came up wit the following error code 0x80070057 and would not open. I have tried uninstalling and re-installing the application to no avail and I wondered if anyone had any solutions to this problem ( I am using Windows 7  64 bit OS). Thanks.
rhorne9
Finally solved the problem by deleting the media library. The programme now opens, and all my music and pictures have been restored. Must have been a corrupted file somewhere. Thanks for all your help.
7 REPLIES 7
profile.country.PH.title
MarlonUk1
rhorne9
Thanks I have tried these solutions but Media Go still won't open.
MarlonUk1
there must be still some registry keys left when you first uninstall the media go, how about when you open media go from pc companion?
rhorne9
Media go will not open from pc companion either. Maybe a system restore will help?
MarlonUk1
yeah, that would be good. try performing a system restore.
rhorne9
dancerdavies
Hi when you say you deleted your media what exactly do you mean? I have an xperia z and an Asus Windows 7 which I can no longer get media go to open. it keeps telling me that it wasn't closed properly. I've uninstalled and reinstalled umpteen times with no luck Slightly_frowning_Face Any advice would be much appreciated.
