Keeps on rebooting
jerre002
Keeps on rebooting
My Xperia U keeps rebooting. I can't seem to find it in the SUS.
I can't access the safe mode (volume down + power button gives a green light) long enough to do anything (since it keeps rebooting). My battery is fully charged.
Volume up and power button gives a blue light, but he keeps rebooting after the 'XPERIA' message.
Any suggestions as for what else I can do?
Kind regards,
Jeroen
alexrx
Enthusiast
Hi there,
Repair your phone with PC Companion.
Here is a detailed instruction:
http://talk.sonymobile.com/t5/Xperia-Ion/Detailed-Software-Repair-Instructions-using-Pc-Companion-Wi...
NOTE: Make sure that your phone is completely turned off and follow the recommended steps!
Cheers.
6 REPLIES 6
alexrx
Enthusiast
Hi there,
Cheers.
profile.country.RO.title
_alexdon_
You can use sony update service to repair if the battery is 100% charged.If you want to enter safe mode,at the xperia logo screen,just tap menu key.
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
alexdon
jerre002
Thanks! My xperia still keeps rebooting whenever I try to connect to wifi..
But now I can at least still use my phone Grinning_Face
_alexdon_
Have you repaired?If you need to see all models in SUS,run in compatibility mode for windows 7.
alexdon
Mg4art
Hello, i have the same problem, did you solve your issue? Can you help me if you did. Thanks
Dr4g0nE
I tried the guides mentionned in the subs. Even though my phone still wont do annything else than reboot.
PLZ!!! help me, i need my phone for work and i´m in trouble if my data is lost
