Well, i dont use my phone for audio communications, i mostly use sms's and skype.
I received a call a couple of days ago and i couldnt hear a thing, i could only hear when i put it the free hands option (i dont know the name of it in english)...i reseted my phone yesterday and before installing the apps that i use the most i did a call and it worked!!! i could hear everything...but when i installed skype..even without using it..the problem came back...is anyone having the same problem with skype? its something recent maybe a recent upgrade to the app? thanks
In that case this problem is most likely related to the Skype application. I suggest that you contact the Skype support to troubleshoot this further on.
