Infected by water, Phone is working fine but backlight is not turning on
noman007
My xperia arc is infected by water damaged by water .. now its touch and all phone is working very well but tere is light turning on.. neither backlight nor any charging indication lights... what to do now...???
take the battery out, sim card, and sd card out > place your phone in container with rice and let it dry for 1 or 2 days, if that doesn't work then there might not be anything left to do but to take it to a Sony repair center, if the motherboard its damaged it will cost you almost the same as a new phone as this is the most expensive part of the phone.
