i just bought my xperia sp 20 days back and after 15 days it stopped to recognize sim card very often.the sony service center replaced the mother and now my imei number has changed.i just wanted to know that does the imei change cause any change in warranty period or it would remain same as of the previous one that is from the date of purchase?
You did buy the original rite?So it would okay,the change of imei will not affect the warranty.As matter in fact,you will have a newer warranty instead
If you want to know whether your phone is original or not,just check it at your imei number.Check the 7th and 8th digit of your imei numbet,if it is "05" then its original..
