ICS 4.0
faisal3dfx
ICS 4.0
Hi Guys, I need ICS 4.0 ftf can anyone provide me one for my Xperia TX (LT29i).
Thank You
14 REPLIES 14
faisal3dfx
@alexdon Bro thanks for your ICS4.0 version but guess what this ICS 4.0 didn't solved my problem still my phone shuts down when it reaches to 50%.
Anyway i have sent my phone to the sony service center and they told me that they will examine the phone and will report me after couple of days.
So now i am waitning for a good/bad news don't know what will happen.
Thanks a lot for your help brother.
profile.country.RO.title
_alexdon_
Sorry to hear that,it might have been just hardware problem.
alexdon
faisal3dfx
Hey alexdon how are you bro? I got my handset back 2 days ago. It's running fully ok now. Battery level decreasing perfectly no sudden drop or shut down. They told me that they replaced the battery and they told me that it was battery problem. As I downgraded my phone to ics 4.0.4 so I told them to update my phone but they did not updated my phone just replaced my battery. Now I am really worried that if I update again the problem could appear again and I don't want to send to the service center again coz they took 15 days this time and charged me $52. So bro what do you think? Should I update my phone once again or should I stay on ics?
_alexdon_
Stay on ICS for a while,see how it works.If everything is fine,you might want to give it a try and update.
alexdon
faisal3dfx
Thanks alexdon.... Slightly_smiling_Face
