I'd like to know which settings are necessary, to switch on my Xperia T2 automatically every time I flip the case open. Tks
So you want the display to turn on every time you open the flip case?I'm afraid that is not possible.
The other colleague (harsarayan) at the Forum mentioned the use of a Sony flip case SCR 14.
I also heard about that from another friend. I have a very good magnetic flip case made in Sweden.
Once, when I flipped it open, it vibrated and the screen lit automatically.
Since then, I have been trying to find out what triggered that, to no avail.
Tks anyway for your help.
Tks, I will try to get a genuine SCR14 Sony cover.
