im using sony ericsson live with waalkman, some softwares and games ask for root my ROM. i have no idea what is that, i have tried to root my rom by installing softwares but it doesn't work. i used Easy Rooting Toolkit (V1.0), i also followd the instructions before rooting but nothing works.
my build number is 4.1.B.0.587
may i know how to root it and is it possible to root my device?
i am currently using ICS on my device.
and my device is a Live with walkman~
help me please!!
Message was edited by: Gameover
I want to root my phone.my build number is 4.0.1.A.0.283
I read some tutorials but I'm confused with flashing.Can I root my phone without flashing? plz help
I'm not aware of this build number
You own a live with walkman ?
go to settings > about phone > take a screenshot and post it here
i need it
Yes I own a live with walkman
I went throught all the resposes given to users.. But i have some queries...
I have lww phone and i have upgraded it ICS and now i m facing too many problems such as camera quality, slow speed, etc.. Since my cell is under warrantee i cannot go for rooting. So tell me how can i get GB installed. And service centre in pune is pathetic as they r not serious in their work.
I even tried downloading flash tool but its showing error in downloading.
Pls suggest....
IshMax i don't know anything about this build. so i can't help you with rooting
But if you don't care about the warranty then you can flash a rom that is rootable and then root it
You will get the latest Gingerbread firmware on your phone
abhresh.sugandhi if you downgrade yourself, then also your warranty would get void
So unfortunately you are left with no option but to go to service center
Already I don't have a warrenty.So I don't care about it :smileygrin:
Please guide me to flash
okh then, let your device explore the world of android :smileygrin:
Now flash the 4.0.2.A.0.42 rom from here
After that reply to that thread only, i will tell the next steps
hi Friends i'm try to install font changer but i cant why....... can i root my sonyericsson.. if how, pls give your suggest
wt19i_4.1.B.0.587_kernal.ftf.............i used this file for flashing
DooMLoRD_v1_Xperia-2011-ICS-ROOT-emu-bus.. used for root
what is the wrong. pls help
