im using sony ericsson live with waalkman, some softwares and games ask for root my ROM. i have no idea what is that, i have tried to root my rom by installing softwares but it doesn't work. i used Easy Rooting Toolkit (V1.0), i also followd the instructions before rooting but nothing works.
after root can I update through offical software like 4.0.5 ICS ?
If there a chace of Brick or complete brick ?
Dear friend , i did root on my sony ericsson walkman live ,then i got a super user folder on my screen but it not active .can you help me how to install ICS on my phone plzzzz
Jun 4, 2012 11:13 AM (in response to AlexSSB)
Re: How to Root Sony Ericsson Live With Walkman (WT19i)
Its not yet known that when will Sony float official ICS update for WT19i. But one can try this amazing ICS ROM: http://www.androidust.com/ics-aosp-rom-for-live-with-walkman-wt19i/.This is a pure AOSP ROM and thus there are some benefits and a few limitations.
Dear Friend uliwooly ,please can you explain me if i download it how to install on my mobile (sony walkman 19i)
You will be able to update without any problem
If you follow every step carefully then nothing will happen
i'm sorry i can't speak english very well, i want to ask how to root lww ics?because i can't root with busy box. must be downgrade fisrt to GB to root?thank's
I came across one method of rooting wt19i on ICS. This method works when the bootloaders are kept unlocked. http://www.androidust.com/root-live-with-walkman-wt19i-with-unlocked-bootloader-on-ics-4-0-4/
Dear Friend ,
i would like Root My sony Ericsson walkman Live ,Can you Help me How to Root it Simple ,
one by one, step by step ( please just Explain to me more ) this Download to PC or Mobile
and How to
do flash ( Pleaseeeeeeeeeee)
. Download this kernel(polish blood project) and flash it http://www.mediafire.com/download.php?z26az3wlh4d144o
2. Go to CWM and flash this package http://www.mediafire.com/?69uuq3jep96xomb
3. Turn off phone
4 Download this kernel and flash it via Flashtool http://www.mediafire.com/download.php?9kivmlu7borsi9s
-Launch Flashtool
-click on bolt
-select Fastboot mode
-plug your phone into the computer
-than click on Reboot into fastboot mode (via fastboot)
-than click on Select kernel to Flash and select kernel.sin
i cant download the flash tool, i dont know why, i have downloaded the rom and zergrush root kit but i simply cant download the flash tool, if u have any other link plz tell me
ok now i have downloaded the file it is flash-update-0.8.x-0.8.6.0-windows.exe it is 955kb file, but i cant install it , it shows flashtool could not be installed, installation will be aborted, what should i do now,
my build number is 4.1.B.0.431
is it possible to root my device?
i am currently using ICS on my device.
