How to Root Sony Ericsson Live With Walkman (WT19i)
im using sony ericsson live with waalkman, some softwares and games ask for root my ROM. i have no idea what is that, i have tried to root my rom by installing softwares but it doesn't work. i used Easy Rooting Toolkit (V1.0), i also followd the instructions before rooting but nothing works.
97 REPLIES 97
THANK YOU NABEL for your posting. I have already flashed my phone. I check this following post too. But I am not sure whether this is the post to do root or not Please make me sure so that I follow it and complete my rooting.
Nabeel wrote:
settings > applications> allow unknow source > development > enable usb debugging
connect phone to pc
it will install 3 drivers on your pc
skip pc installation
download this http://forum.xda-developers.com/attachment.php?attachmentid=841876&d=1325678726
and extract using winrar
click on bat file and follw the process
Nabeel
Master
Yess it is the whole process to root
do it Slightly_smiling_Face
michaelrajx20
I downloaded the flash tool but not able to download the ROM file its showing the error message as "
This file does not exist, the access to the following file is limited or it has been removed due to infringement of copyright.". Please advise.
Nabeel
Master
Download from here, ( roms given in a table , download 0.42 or 0.58 )
michaelrajx20
Thank you for your prompt response. I downloadeded the 0.42 Rom and placed in the following path C:\Flashtool\firmwares and then run FlashTool.exe then it open up the software. When i clicked the Flash icon its shows Flash Cancelled. Please advise. LW.JPG
was your phone on flashmode? to root use SuperOneClick
ok I see what happened, you probably moved the usb cable and/or released the back/volume button too early
check the video on how to flash here
http://talk.sonymobile.com/thread/38251
ryannsagun
sir.. i'hv done this process too and it is succesfully done, but in the menu there is no app SUPERUSER has been installed. now how do i know my phone is successfuly rooted?
connect phone to pc
Nabeel
Master
You should follow the whole rooting process again
you are on which firmware ?
if on 0.62 then its not possible to root it
ryannsagun
sir... my firmware is 4.0.2.A.0.62. Neutral_Face
