How to listen music from car with bluetooth?
barisist
Hi, I am using sony ericcson xperia arc. There is no problem while talking with my phone in the car and using bluetooth. What I wonder is "is it possible to get sound from car while listening music from the phone?"
I tried sth. but didn't work. Thanks for any help...
Sam
Legend
Legend
The Xperia Z does and from my understanding so do all current Xperia handsets. I do not have a list of which phones do support this other than that but the white paper for each phone (can be located in the documents section of the support page for each phone) does list this.
Please be aware that your current phone does also support this but it is if the car kit supports this that is relevant in this case.
4 REPLIES 4
Sam
Legend
Legend
If the phone is connected to the car kit via Bluetooth it will automatically stream the music audio to this device if the device supports this. If you have tried and it is not working then unfortunately it sounds like the device does not support the A2DP Bluetooth profile required for this function.
barisist
Dear Sam Thanks for answer.
Is there a way to understand which sony smartphones support A2DP Bluetooth profile ? I may change my phone soon. Does xperia Z support this ?
Sam
Legend
Legend
barisist
I understand. So the problem is the car kit. It is hard to change my car Slightly_smiling_Face
Thanks for help.
See u Slightly_smiling_Face
