Hi, I have noticed many people when they do a status update through their sony phone it shows as sent through sony xperia smartphones.. I am unable to do that. when i use the FB application from the phone, it just says sent through mobile..Can anyone help me out with this ??
FYI: I have activated the integration feature as well but still no use.
goto Timescape™,
get FB signed in.. right soft key, set update status..
hope that helps..
Thanks for posting and welcome to the forum!
Correct what bluechip850 states. Make sure to use Timescape and it's posted as from your Sony phone.
What do you think about this forum? Let us know by doing this short survey.
Thanks a ton
you are most welcome...:smileyhappy:
its not working..unable to install thin Xperia M .Single SIM version..HELP!!!
how to go to timescape?
