How to disable vibration of top three buttons?
Hello, Anubdoy knows how to disable the vibration for top three buttons in Xperia U?
Jake-SonyXperia
Champion
To remove this function simply do the following,
Menu > Settings > Sounds > Un tick Haptic Feedback
That is all that is required to remove this feature.
3 REPLIES 3
Jake-SonyXperia
Champion
Menu > Settings > Sounds > Un check Haptic Feedback
Above settings work as said by Jake Slightly_smiling_Face Even I did it that way.
murtibing1
there is nothing called haptic feedback under settings> sounds> on my xperia u
