How to disable developer option
samrocks
By mistake i clicked thrice on the build number and the developer option appeared on my settings menu
After that my battery is draining very quickly and even in idle mode when m not using the phone..
Can anyone plz tell me how to disable it from the settings menu
Plz help
Tags (1)
19 REPLIES 19
profile.country.RO.title
_alexdon_
Jake,that is a drastic solution,you have a more simple one.
alexdon
samrocks
Clearing settings data will wash off everything from my settings
Isn't there any easy way for it..
_alexdon_
If you clear data for the settings app in settings-apps-all-scroll down to settings,you will not lose much,but if you reset to factory settings,you will lose internal memory.
alexdon
samrocks
Thanks alexdon..
It worked
_alexdon_
Anytime.
alexdon
Ehsan120
Tnx Alex, it's worked very well  Slightly_smiling_Face
Tags (1)
_alexdon_
Nice to hear.
alexdon
Rumrai
Thank you to @alexdon, now I know how to fix it .
Please be informed that your advice of this issue is working well on Lollipop 5.0.2 software 14.5.A.0.270.
Anees1
Worked. Thanks
PankajPyasi66
My phone don't have navigation bar setting. So how to navigate the back or recent function
