How to detect original Xperia P
saif1618
Hello, I am worried that my new handset is original or not, I bought Sony "LT22i XPERIA P" about 1 week ago, after back to home I checked my IMEI in http://www.imei.info & it is showing my handset is samsung 'I5700 Galaxy Spica'. Then I claimed for another new handset to the distributor's head office. They ensured me, their higher officials checking my case. Yesterday they called me & said its not any clone set or smuggled one, they said that website is showing wrong info. But still I am not sure my handset is authenticated or not. If their is any support to check my IMEI on your database it would be very helpful for me.
Regards
Sam
Legend
Legend
If you have no luck PM me your IMEI and I see what I can find out for you.
10 REPLIES 10
Gokul_Bontha
check with sony service center if you have original bills
saif1618
theres no sony service center in my country, so I did come here Slightly_frowning_Face
I can provide my product details/ IMEI to any official support agent to check if it is original or not.
Gokul_Bontha
Call on customer care...
They will i guess
saif1618
sorry mate, there's also no care center here Slightly_frowning_Face
profile.country.RO.title
_alexdon_
Check this site http://www.numberingplans.com/?page=analysis⊂=imeinr
Fill the IMEI in the box and see the results.
alexdon
Sam
Legend
Legend
saif1618
yeah, I was waiting for an authorized support's answer, but getting an error while I went to pm you.
Regards
Message was edited by: Sam - removed IMEI.
Sam
Legend
Legend
I have removed the IMEI from the post for you and will PM you what I have found.
saif1618
Thanks for the response dear, theres many clone set in our country, Xperia is very popular here, but there's no authenticated reseller or support here, so its came to my mind, have I been a fool? Got the answer from you Winking_Face thanks a lot, keep up ur great job:smileyblush::smileylove:
