HELP!!! Exclamation & phone symbol only on screen
I need help big time. This morning after i had installed Sony PC Comonaion, i then tried to update my sony experia arc s to the ICS. It then gave me a message saying that i could not update.
So i unplugged the cable from my phone & then tried to turn it on as for some reason it had turned off.
All that came up on the screen was the words sony then an image of a white triangle with a yellow exclamation mark and a picture on a phone.
Does anyone know what this means & how i can fix it?
slimshaddy
Hero
update your phone with this..
http://www.sonymobile.com/global-en/tools/update-service
this is an official sony software so don't worry..
and if it says your phone is up-to-date click on install anyway..
this will solve the problem.
3 REPLIES 3
slimshaddy
Hero
You are a Legend! Thanks sooo much for your help. Slightly_smiling_Face
Dheisenberg
I have a black screen with a white triangle that has tools on it and a loading bar down below
 How could I fix that?
