My phone about a month ago I upgraded to 11.2.A.0.33. I've done this with phone WiFi. After installing a program infected with the virus, I had to use the firmware 11.2.A.0.31. Now I want to upgrade my phone to 11.2.A.0.33, but the update does not appear on my phone. I did not even link to download the file 11. What should I do.
Thanks a lot
At this point you have 2 options
1) wait for the update is approved and released to that new firmware
or
2) download .33 ftf file and flash it
What do you mean infected with a virus?
Thanks for your response. Please .33 ftf file link
The Infected file: An application after installing it, the phone was constantly restarts.
