Hazel j20i phone not working for other sim cards except the using sim card
I have a j20i and it doesn't have any problem with it except it is only working for one sim card which i'm now using and if i inserted another sim card phone isn't starting. Please help me on this error
8 REPLIES 8
Dr_Chris
Champion
Are these other SIM cards for different networks? What error message are you getting? It sounds like your phone is locked into a particular network, so it will not accept SIM cards from other networks.If that's the case, you'll need to ask your mobile operator for the network unlocking code.
mohanraj491
FOr me too having the same problem. am getting a feeling like i want to throw it into dust bin. how to solve this. it is been 1yr only.  i bought my mobile last august. but for first one month it worked fine. even i change sim when i go home town. it will works. all of sudden. one fine day it got locked to one airtel sim which is am using mostly. now a days when i go home when i change my sim. it wont work. i mean my phone shows symbol that it is going to be switched ON. but it wil not ON . i kept it for a whole day. but it didnt got ON.  i don know wat to do. >> any solution please???  And another thing is i cannot able to configure gmail box. in my mail box settings. it wil ask for manual configuration. for the first time when i bought my mobile facebook widget , mail box. everythng worked fine. but suddenly i got that sim changing problem right. from that time onwards these things too stopped working. this is my new phone Slightly_frowning_Face
Dr_Chris
Champion
Where did you buy this phone from? Was it new?
Azuadee
the same problem happen to me..but i ve just find a way to solve it..
i'd used simcard MAXIS HOTLINK (MALAYSIA) with my J20i for a year then
when i try to use another simcard, my phone cannot be start..what i do to recover this prolem is, i ve just turn on the pin code for the new sim card using another phone then i placed it back into J20i.For sure, when i turn on the phone it will ask for the pin code..then i ve just simply enter the pin code and its working...PROBLEM SOLVED!!! Slightly_smiling_Face Smiling_Face_with_open_mouth_&_closed_Eyes :smileylaugh:..
Tags (2)
woon86
simple way but great solution. tq soo much.....
nendy
Thanks dude, its very simpling, my hazel back life again
amnesia7
After getting my phone unlocked and it still failing to start with the new SIM I'd almost given up until I found this post suggesting to use the SIM lock on another phone first...worked a treat. Thanks Slightly_smiling_Face
Suresh1996
How can I solve this type of problem
