Hard Reset Xperia P
majidshirazi
Hard Reset Xperia P
hi
i forgot my password and now i can not log in to my xperia p!!
i can not  use PCC because i needs to be unlocked(that is not!!)
how can i reset or remove the password??
or how can i hard reset my xperia p??
i used pressing up volume key + power button but i didnt work!!
pls help me 😞
Fahim715
7 REPLIES 7
Fahim715
Watch this videos
http://www.youtube.com/watch?v=Sb7kET168nk
Hope it work Slightly_smiling_Face
majidshirazi
really thanks Slightly_smiling_Face
Tags (2)
endel29
hi man i have the same problem how did u did it?:smileyworried:
profile.country.RO.title
_alexdon_
You need sony update service.
alexdon
kashif25s
Sir , I did master reset to my Xperia P through software menu. battery was 100% and now I am waiting for last 2 hours.screen is blank and three lights of transparent bar are illuminating.please tell me is there something wrong and how much time it normally takes for master reset?
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
mahes
My phone switch on message unfortunately experya not support
