FATAL Ray Problem After ICS 4.0.4 update
drjosephedward
i don't know how to explain this... but
i had .42
then .62
then 4.0.3
all with the usual problems/bugs everone had...
but... after 4.0.4 update, a big problem appeared...
whenever the screen is ON, and i leave it idle till the light fades, then it goes OFF.. right?
if i press ANY key instantly after it goes OFF, it goes back ON
if i am late 1-2 seconds, it turns back ON to a BLANK BLACK screen (like the one when you turn the phone ON and there's no logo yet)
no whatever i do it stays BLACK...
if i press the above lockscreen button, it turns OFF, i press again, BLACK again...
i have only ONE SOLUTION
leave the phone for 30 seconds minimum...
then when i press any key, it gives me the lockscreen screen...
now what sucks even more...
i tird reverting back to .42
and the problem persists ... so i guess 4.0.4 caused some hardware screen issue !!! Slightly_frowning_Face
help Slightly_frowning_Face
drjosephedward
well, it ended WELL
they admitted the hardware issue (they said it's a motherboard failure)
they replaced the phone (well they gave me my old battery & backcover) because their policy says they only replace the WHOLE phone with the box in the 1st 14 days of purchase.
so everyone having this issue
IT IS A HARDWARE ISSUE, PHONE MUST BE REPLACED !!! NOT FIXABLE !!!!
41 REPLIES 41
drjosephedward
i guess i'm stuck here...
no other way but to get the time to give it to the service center...
which i KNOW will be the hardest time EVER, knowing that i am a fulltime doctor and they are fulltime employees trying to avoid fixing, paying or even diagnosing any problem and always blaming it on the customer... (just as any other service center in Egypt)
drjosephedward
http://www.youtube.com/watch?v=m4p0-kv1cxA&feature=plcp
this is my own video of what happens exactly
Veresova
This may cause some external application. Try a factory reset. Before the backup.
drjosephedward
i did a WHOLE firmware repair from PCC
then a factory reset...
i'm pretty sure now that it's a hardware issue Slightly_frowning_Face
Veresova
The videos are not factory applications.
To repair Sony PC Companion.
If the problem is not corrected then it will be hardware problem, you must visit the service center.
drjosephedward
yes, cause when i repaired it, the problem persisted ... i tested it with the 1st wizard that comes when you install ICS...
so - hopelesly - i continued installing my apps as i need to USE the phone...
it IS a hardware problem
btw, i'm not a noob or an average user, i have 2 other android phones (Xperia X8 and Motorola Fire XT)
both rooted and X8 with a custom ROM
but MY RAY was NOT... it was STOCK all along the way Slightly_frowning_Face
please help me  I have this problem now may screen BLANK BLACK screen
please help me
drjosephedward
now this is strange...
i've just come home from a long shift at the hospital, durin which is used the phone 4-5 times to make calls (and the problem occured once)
now i'm sitting (quite good temperatue, phone has been idle for several hours)
and i CAN'T REPRODUCE IT
now i KNOW that when i put the charger ON and it gets HOT while charging, the problem will come back...
huh ?! Slightly_frowning_Face
drjosephedward
[CONFIRMED]
it IS an overheating issue...
once i started using the phone for a few minutes, then put the charger, it was INSTANTLY reproducable !!!
and after finishing charging, and leaving it for a while to COOL OFF, it was UNreproducable again...
