Facebook Inside Xperia Problem
bryle_magat
Hi.. I have a problem also about facebook inside xperia.. I cant activate  it. Even though I turned on the sync. After I checkd the box to enable  it, and agree to the terms, it just go back from unchecked box. What  should I do to activate my facebook inside xperia?? Help!!
my facebook is working but,, my "Facebook inside Xperia" is not working.... help..
9 REPLIES 9
Johan
Master
First check that if this happens independent of Internet connection. Try both mobile networks and Wi-Fi. You can also check if you have any proxy settings in your APN settings that might be causing this.
If not you can try reinstalling the phone software to make sure it's just not a software glitch.
bryle_magat
Thank you for your reply..
i dont have a Micro Sim yet,, is that affect the "Facebook inside Xperia?"
. and is there any more solution rather than reinstalling the software? because i did that already and nothing changed...
Kishan_2212
Which Mobile You use....?
i have same problem in my Xperia Z when i start uploading pic from "Xperia for Facebook" it is always finished upload but i cant see that pic on my facebook account.
this problem occuer after when i update my Kernel Version.
khush
My phone shows that ..this page cant be opened right now..it may be temporary unavailable or the link you clicked on may be expired...and soo on..plz hepl me
Sam
Legend
Legend
@khush - Are you using the actual Facebook application or browsing to the page?
What are your thoughts about this forum? Let us know by doing this short survey.
feveel
I have a problem in uploading photos thru. facebook inside xperia, it always shows photo uploaded but it doesnt show on my fb. How do i fix it?
Sam
Legend
Legend
It may not show up on your timeline, however have you checked yor albums on your Facebook page?
vai
Hey.. I have an Xperia U.. The facebook inside Xperia is not working.. Everytime I try to open it.. It crashes!! I tried updating the app and reinstalled the software.. It's of no use.. How do I sync calendar and other stuff
122436
