Hello
For several months I have constantly appears a small window on top of any application. in the box there is no text, only the button ok.
Sometimes there is more than one. So far, so you will not close, nothing can be done.
I'm not sure, but I think this window has started to appear after the last firmware update.
He did a full system recovery, and the first thing I saw on the screen - it's a window.
Screenshot attached.
Phone: Xperia S (LT26i)
Android Version: 4.1.2
I hope to help ...
You are welcome!
Real glad that your phone is well behaved again.:smileysmileywink:
Hi, have your tried repairing phone software with PC Companion or Update Service? It could be a software glitch.
http://www.sonymobile.com/gb/tools/pc-companion/
Be aware that this process will erase phone data completely, backup if necessary.
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
Can you post the screenshot again this one is not working...didn't get the problem properly..!
Now see the screenshot?
Reinstall the software did not try. Today I'll try.
Fingers crossed and keep us updated.
Greetings.
For more than a day after reinstalling no windows does not appear. So everything is working fine.
Thank you very much!
Sooner I was delighted. Yesterday there was this window again. So reinstalling the firmware did not help.
Who can help me?
