I have purchased Xperia Tipi single SIM on 11th of November on Diwali festival. I have started using on same day and when I was calling to few of my friends then they complain about my voice and inform they are not able to hear me Cleary and they are gating their ECHO itself on their cell phone. Initially I thought that this might be issues due to network operators.Same issues was continue more than week then done two tests
.I tried by inserting other SIM cards to my phone and then celled to same numbers –Still ECHO was thereThen I want to service center –where I have given my cell phone for investigation and they inform they will take 10 days for detail investigation. During one hour of my waiting period there were three Tipo user arrived with same complain ,out of them one got replacement as he came just after 3 days after his purchase.As a phone voice quality and cell connection as basic characteristics of any basic cell phone. Now hoe come sany haven’t captured in their testing cycle. Its very bad for user that Sony failed to provide basic smooth call connection to user.If this issues is not solved then I will file case against SONY Mobile in consumer court.
T
Sam
Sony will never solve this problem. Its been a problem since at least october 2012 to my knowledge. Change your phone. But dont get a sony lol.
You should now be able to tell the approximate time for the software update..its almost been a month you posted about the update..
Any info..is very well appreciated
IS Sony Dead in this forum,,,,it has been almost a month and half that there will be a fix...but no exact time even after the 45 days..is too bad on sony and its forum updaters...
I think sony is dead..!
As there was no support from sony and its authorised service center's on my issues with and failed device (tipo), luanched a case with consumer court on friday
I have some problem with Tipo Dual too. Sony Contact Center advised to upgrade my phone. But my phone has the latest firmware (11.0.A.6.5) in my region....
Did any one got any solution for this problem.
I am also facing echo problem with sony xperia tipo ...
Waiting for the solution ...
