Guys n specially Sony Team plz tell me whether the Local Sony Service Center can Downgrade my updated(ICS) Sony Xperia U to my old Gingerbread as i m totally dissatisfied and disappointed with the ICS update.
The major Disappointing factor is the 1) CAMERA, which was one of the reason i bought Xperia U, but after ICS update its quality actually detoriated, lot of noise, poor processing and image improving, delay in capturing and the camera after switchin on if u move camera its something like motion! i didnt like it.
2) Even the brightness is very low( i guess this is the one reason how sony improved battery life!!)
3) appearance is great but overall ICS slowed down the gadget.
4) some benchmarking apps showed my Xperia U above well known Smartphones.(Proud Feeling!!!)
5) ICS introduced the walkman audio player ( still the older player was better)
6) by removing Gallery option Sony made this Smartphone TOTALLY MESS!!!! previously each pic n vid was segregated in folders.
7) lastly i cant understand why sony does this, why cant the Birthdays mentioned in Contacts Sync wiht Calender???? this option was in my old Sony Ericsson K750i.
SonyEricsson(now Sony) was the best Brand for me, but nowadays i feel everything was good till SONY had Ericsson Attached with it. SONY Plz. dont disappoint us.
Thanx
force GPU can cause instability with incompatible apps. Its not advisable for everyone.
Please mark Correct and Helpful answers and you can also visit my blog at: arnabghosal1989's Blog
Hey Frnds,
Yesterday i successfully Downgraded my Xperia U to Gingerbread by visiting the local Sony Service Center.
Now i m happy with my Xperia U.
good to hear that you are enjoying it.
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
This is the correct answer, I just registered to point this out, I backed up
with sony companion, reset the phone to factory settings, and restored form sony companion.
After that my Xperia with ICS, this time working fluently.
PS: some Apps couldn't be restored, but the important data did, just download again the apps.
Me also, I've just registered to say how my Sony became better lol
But i'm having some problems with wi-fi connection. when it's on much time i can't turn it off, it just starts to work properly after reboot :S
still no problem to me...
I worked so much with wifi. Please check the links given here to see if they help.
http://talk.sonymobile.com/message/312915#312934
thank you kindly for this info , i followed your advice and now my phone has dramiatically improved and i now have also regained/unhidden my 3d camera functions and albumn.
thanks again :smileygrin:
how much they charged for u in downgrading ur xperia u mobile
I tried to check the option "Use 2D Hardware acceleration in apps" and i noticed a bit different with my xperia u... it bacame faster...as of now. i will try to observe in the next few days.
Thank u very much for the info
