I'm on T-Mobile (UK) and can't send picture messages. I've gon through all the help on the t-mobile site but nothing has worked. Does anyone know how to fix this problem?
delete them all, uninstall mcafee, taskillers, other antivirus and battery apps and add those 2 APN bellow
That's sorted it cheers
Re added the info on T-Mobile site and it's worked
Anytime
What is mms and how to set it up. When I send picture it is on qued sending.
