In order to backup your TA partition you need to have Root without unlocking your bootloader
Yes you will loose image quality but if you are wanting to root then you don't need to unlock your bootloader on the Xperia U but if you want to install custom Roms then yes you do
Thanks, I'll backup my TA partition.
I have unlocked my bootloader without backing up my TA partition. And I lost my DRM keys and Camera Image quality.
But I have been digging around and found the fix for DRM keys here
and now can download Gracenote music info. So hoping there might be away to even restore the camera quality by placing some lib file like some .apk or .so files. I need it badly . Please let me know.
If there is a way then you'll probably find the answer on XDA
Where can I find details of fixing DRM keys?
