- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Last night my phone started acting weird and asking if I wanted to copy contacts from the USIM any time I tried to look at my contacts. I ignored it most of the time, but earlier today I tried turning it off and on again to see if that would sort it. Now it literally won't do anything, apart from display a message saying "Insert correct USIM". 😕 I haven't done anything different with it that I can think of that would have caused this. I've already tried removing the battery, sim card and memory card but nothing seems to work.
Any ideas whether it can be fixed, or what could have happened in the first place?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
First, try running the SE Update service on it and see if that fixes the problem.Also, try using a different SIM card to see if it behaves in the same way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks so much for the fast reply! I did what you said and run the update software. It seems to have worked perfectly. Thanks again for your help!
