Battery usage menu
Randy_Joe
Battery usage menu
My Battery usage menu only has one program running thats googleplay at 100%. Is this normal? Usually you get a list of apps running but not on my phone. ps i have a experia z2 (2 days old) and how can i make those battery usage menu screenshots?
Tags (1)
Johan
Master
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Sometimes it takes some time for the battery usage feature to settle and figure our what's consuming power.
I suggest that you run the phone as normal for a week then check the battery usage meter again.
You can make screenshots with Xperia Z2 by pressing the on/off key and choose Screenshot.
2 REPLIES 2
Johan
Master
spixel
I noticed this too yesterday but never happened before.
