Battery Problem
James397
Battery Problem
Screenshot_2014-02-03-19-39-19.pngHello,
I have fully charge my phone but its work only 5 hours.
Screen takes 30 to 50 percent battery.
Tags (1)
17 REPLIES 17
James397
Which output do you recommend to me..?
profile.country.RO.title
_alexdon_
Even my Xperia P adapter has a 1500 ma output.Your SP has a 2370 mah battery,so I would suggest somewhere around 1,5 A output.
alexdon
James397
Okay... Thanks for you support.. Grinning_Face
_alexdon_
Anytime.
alexdon
ankit20dec
Most of my Xperia Sp battery is drained by "ANDROID SYSTEM"(35-50%).
And moreover "ANDROID OS" takes upto 3-4% battery.
In most of the phones there is no battery drain by "ANDROID SYSTEM" so why in SP? And the battery used by "ANDROID OS" is 3-4% only.
Tags (3)
0102
Hi since update my Fon. To kitkat my battery drain very fast.I need to charge it twice a day please help me thanks
nsanelazarov
Guys, there is a process Media running everytime you restart your phone. It keeps working all of the time, depending on the quantity of your files. Kill that process because it already has knowledge of all of your files, and its working for nothing. I have read on other forums that is a 4.3 bug, not Sony's fault. I'm not a tech dude so take this with a pinch of salt. But it helped me. Slightly_smiling_Face
gareth-j
Hi there,
I recently changed my phone to the SP less than six months ago and i have had nothing but problems with this phone. Battery life i awful, i am losing on average 10-15% battery iife per hr, and this is without using it. Wi-fi, blue tooth, background apps are all switched off, yet day by day the battery life is getting worse. I can no lonnger leave the house without making sure i bring the charger with me. On average i am getting less than 7 hrs a day of usage from the phone without having to charge it up. Its not as if i am using it for email or phone calls as i have a work phone for these.
Secondly when i do open apps, such as messages etc, i am continually getting a message saying "app is not responsive, do you wish to wait, close or report". AAAgain this is happening every single day, i have tried uninstalling apps such as facebook etc but problem persists. Thenn the phone will just sometimes decide to switch itself off and i have to wait 20 mins to tru and get the phone back working.
Tis is my very first sony phone andd it will def be my last, i am just so fed up with the problems i am experiencing with this make. Any help would be brilliant, before i resort to using two cans and a piece of string attached to them as an upgrade to my current phone.
