i'm using XP for FB and chating, battery about 40%
but something my battery lose to 0%, i cant boot my phone.
then after i pluged the changer that can boot up again.
What will happen if i living out my home?
Can i fix it at service center? i'm living at Bangkok, Thailand.
I'm using build 6.0.B.3.162 for a week, No problem with battery drop and signel.
I'm using full day for 3G signel.
I'm using xperia ion and getting the same problem, the level of battery drop from <=40% or higher to 1% then shutdown unexpected,
Repair the phone software.
u mean i have to format my phone with all software should be cleaned so how can i repair phone software
huysteven1 68 here's how
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions
http://www.sonymobile.com/global-en/tools/update-service/
I also have the same problem i try to repair software through Sony PC Companion but it is not working for me. I don't know how to do with it anyone help me how to fix? Or I have to wait JB release for Ion but i afraid event JB also have the same problem...:smileysad:
I did factory data reset, uninstalled Mcafee, still no positive result
I also did pressing power and volume up button for 10 seconds and restarting the phone, still the problem is not resloved
I repaired the phone through SUS, still i am facing the same issue....
I activeted stamina mode and Low battery mode, still there is no improvement
I have purchased this phone on November 2012 and after 3 months phones speakers were not working
So I had to go to the service center. After this issue was resolved, I am facing the battery issue.
I am fed up with these issues...
can anybody provide me a permanent solution for the battery? is this the software issue or battery issue? and if this is the battery issue, what am i supposed to do. I mean battery will be replaced or not since it is inbuilt with the phone....My phone is still in warrenty period
and here is the snapshot of the battery consumption
hii nabeel
i m also having the same battery problem.
mobile: sony xperia u firmware:6.0.B.3.188 android 2.3.7
the method of repair which u hav provided above will only repair my current firmware or it will update my phone to the latest firmware.
i dont want to go to ics as xperia u lags a lot.
The method given by Nabeel will repair by installing latest software.
