Battery lose from 40% to 0% ... that need changer to boot again
i'm using XP for FB and chating, battery about 40%
but something my battery lose to 0%, i cant boot my phone.
then after i pluged the changer that can boot up again.
What will happen if i living out my home?
Can i fix it at service center? i'm living at Bangkok, Thailand.
32 REPLIES 32
Thank you, Nabeel
I'll backup and repair tomorrow.
Then i'll report the result in the next few day.
Hi, guy
I tried both of PPC & SUS but no software update for my phone.
I'm using on 2.3.7, build 6.0.B.1.564
What should i do next?
or I only do the factory reset?
(See pic but I'm sorry some programes I'm using in thai.)
(Click to see full pic.)
http://upic.me/i/c5/vnppc.jpg
http://upic.me/i/7d/29untitled-1.jpg
aayushjain1987
I also encountered the same problem with Xperia P .
Then i followed this method and everything works fine now :smileygrin:
Nabeel
Master
aayushjain1987 all users except ordinary_man reported it to work
Glad to know it worked for you as well Slightly_smiling_Face
ordinary_man did you use flashtool to flash your phone ?
To Nabeel
Yesterday my phone work better after do factory reset.
But about 10% left bettery drop to fast.
I just found link about flashtool and stock rom.
Which rom should i use?
Reflash Build 6.0.B.1.654 or New flash WORLD 6.0.B.3.162 ?
Nabeel
Master
Do not use flashtool to flash any rom
I was asking if you flashed any rom earlier using flashtool ?
if not then everything is fine
do not use flashtool, soon you will be able to repair your software using PC Companion only.
Since the sudden drop has imporved , manage with it until you are able to repair using pc companion
My advice Slightly_smiling_Face
Oh... that too late.
I already flashed by flashing tool for few hr. with Build 6.0.b.3.162
Because I cant repair by PPC & SUS, then you told me like i did something wrong about my phone.
then i wanna try to use the orginal rom.
I hope my phone will be fine.
I'll report in the next few day.
(I have used LT15, LT18a, I never update success by PPC & SUS. Idont why, That's why I used flashtool)
Thank you, Nabeel.
and now, Could  you tell me where I can find the original 6.0.B.1.654 ?
Nabeel
Master
Although there is no harm in flashing using flashtool , i just said because your mobile is new
anyways you will be able to find firmwares at xda Winking_Face
At xda that I found 1 link. but really slow downloading.
Than I'll use 6.0.B.3.162 for few day.
Thank you, guy.
I'm using Build 6.0.B.3.162 for 3 days, No battery sudden drop anymore and signel like normaly
I'm happy to using xperia P now.
Have a good day. Slightly_smiling_Face
