Unable to watch video with proper audio along with it. This happens when viewing video online like youtube, facebook and others. But works fine with local files on internal and sd storage.
Things tried: clearing data, clearing cache and restarting the device.
What else to do ?
Check if you experience the same while on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
I use a 5mbps internet connection and I do not think this is a problem as video runs good on other devices.
And I use official app from playstore (youtube and facebook) updated versions.
Works great on safe mode.
How to get the same quality in normal mode?
It's a third party creating the issue, an antivirus, taskiller, battery apps, etc.
I have no apps like that. I just have some apps like ebay,skype and other stuff nothing much.
I use no apps to modify phone settings.
You will have to uninstall an app at a time to find the culprit, again, it's not a preloaded app but an app that you've installed at one point.
