Hi everyone,
According to Sony Bridge for Mac, my device software is up to date.
My the phone, it's running Android version 4.1.2, build number 12.0.A.1.211
Is the device software up to date?
If you have the possibility to stay with 4.1.2, don¨t worry since that was the last time my phone worked like it should. From that on update after update another problem after problem. I have decided these two were the only Sony smartphones for me - The first and at the same time the last one!
Company that should keep on making televisions should not be making smartphones!
The only SP phones on .211 are Malaysia and commercial aka Store demo or Journalists
Thanks for your reply.
I actually bought this phone from Hong Kong.
Does it mean, the phone will be staying at Android 4.1.2?
I don't have this answer reagarding staying on 4.1.2
But HK C5303 Customization number 1271-7847 Generic is on 12.1.A.1.205
and Number 1272-5249 3HK is on 12.0.A.2.254
Thanks for your reply. I would stay with the current software release.
