AMAZING battery after update to Lollipop !!!!!
Reventon
After a very hard time (I almost threw it in trash) trying to update my T2 Ultra Dual to Lollipop, I succeded, and the phone is better now.
What surprised me is the battery performance now, as you can see on this screen I just took:
I also use Qualcomm's Battery Guru.
I'm very happy with my phone now because battery is something that I really need, even more than processor.
Great to hear that, thanks for sharing
19 REPLIES 19
Thommo
Don't be fooled by that time - In 2 or 3 days time when your battery usage is measured it will return back to normal and a time that your device guesstimates based on your usage over those 2 or 3 days what the likely hood of continued use will result in your battery life time
1adrian1
That's because their is no previous usage data to give a estimate from as those figures are just estimates on how long the battery will last based on previous usage. It may as well say 12mths
Reventon
Too bad Slightly_smiling_Face
Yeah I know it is a estimation, but still, I never had those numbers before.
I'll keep tracking the battery in this topic. It will be fun to check how far it will go.
Reventon
Day 2:
things got back to normal. But still are great numbers.
Reventon
Day 3 -> 73%
Reventon
Day 4  -> 65%
profile.country.RO.title
_alexdon_
That is too much I think, are you sure you haven't charged the device even a little?
alexdon
Reventon
Not at all. But I'm using it very few.
But like I said: the battery performance has improved a lot.
