Hello,
I have an Xperia SP and about a month ago I set an alarm for work to ring at 6am. In the past few weeks I noticed I wake up late and figured perhaps I never heared the alarm go off...
This morning I happened to wake up at 6:50am and noticed that the alarm was set to 7am and it did go off at 7am. As soon as the alarm stopped it showed the next day's alarm at 6am again.
So it seems that even though the alarm is set for 6am and it shows for 6am it only goes off an hour later at 7am. Has anyone else experienced this? I live in Toronto, Canada.
-Ahmed
Sounds strange! The alarm clock should ring when it matches the time shown in the upper right corner.
Try to clear data for the clock. Go to settings > apps > all > clock > clear data. Restart phone and try to set an alarm again.
what is your snooze period?
Snooze is set at 10 minutes but thats not the issue.
I'll clear the data and try again then report back.
Since clearing the Clock application in settings the alarm has been okay.
