Help needed.
My phone is xperia V lt25i jb 4.3 build number 9.2.A.2.5
Recently i stumbled upon a too good to be true apk that i thought could have changed my phone's home launcher to a xperia z3 home launcher. I moved the new home.apk (z3 launcher) into system/app and replaced the original home.apk that I had and reset the permissions. This caused my phone to bootloop and I had to factory reset. After restoring backup, I got everything running again. Except some applications would have errors and force close when I'm running them e.g phone, contacts, xperia home, etc. I had to use a different launcher but that didn't solve the other problems.
Currently my main problem is that I can't seem to save any number in my phone, yet alone open the dialer or the message.
Can someone please help me out. I tried looking everywhere...
All you can do is to try performing a system repair - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Thanks Thommo and Uliwooly!
I did the system repair and now it's up and running
Anytime
