About Cyanogenmod
faisal3dfx
About Cyanogenmod
Hi guys, I want to know that is there any cyanogenmod kitkat version available for xperia tx (Lt29i)? If any stable version available please let me know and if I unlock bootloder will I lose Bravia Engine? Also as . Don't know anything about installing custom roms so I need a good tutorial too.
Thank you.
_Lemonassassin
You can backup your ta partition, (there are several tutorials in YouTube). This partition contains all your DRM keys you need for the bravia engine etc.
If you want to flash a stockrom again you can restore your ta, but this also locks your bootloader again.
4 REPLIES 4
Thommo
If you unlock your bootloader yes you will loose Bravia engine as well as other Sony extras, As for CM then it's best to check XDA
_Lemonassassin
faisal3dfx
@_Lemonassassin thank you so much bro iwas just looking for this info.
Thommo
But you'd need root without unlocking your bootloader 1st
