Why does my sony bdp S370 not play blu ray discs
michael733
Why does my sony bdp s370 not play blu ray discs, it will play standard discs but not blu ray.
It is up to date with software updates.
Bravia55HX
how longs it been doing that?, i would strongly suggest you return it to the store for a replacement.
Bravia55HX
