STR DH790
tonkie93
STR DH790
Hi
I’m looking into buying the STR DH790, but as we know they don’t come with speakers, so has anyone got this amp? if so what speakers have you got, or can anyone recommend me some.
I will only going 5.1 and would want the front and back just smaller  wall mounted ones.
Thanks in advance
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
You can see some reviews for the STR-DH790 and what speakers other users have paired the Receiver with on the Sony website here.
Hope this helps.
Best wishes,
Sean
tonkie93
Hi Sean
thanks for that, I have read the reviews and almost certain I’m going for it, but will just hold back until, hopefully someone on here comes and report on their speaker set up.
again thanks
Sean_Mc
Moderator
Hi again,
You're welcome!
I hope someone in the community will be able to help further.
Best wishes,
Sean
tonkie93
Well bought the 790 and went for the Yamaha HS-P41, budget maybe, but suits me and more than happy with the sound, certainly an upgrade from my aging JVC all in one😀
Just need to get my head around all the settings
