SONY home cinema BDVN7200WB need a minute to come sound after turning on tv
dovydax
Hello, SONY home cinema BDVN7200WB connected by hdmi cable arc with Sony Bravia kdl  tv. When I turn on tv sound through home cinema comes out about after one minute. How can sort it out?
3 REPLIES 3
Sean_Mc
Moderator
Hi there,
Can you let me know the model number of your TV?
Best wishes,
Sean Mc
dovydax
It's Sony bravia kdl46w905a
batee5
Specialist
Hi dovydax,
Welcome to our community!
I'd like to know more information about the issue. Do you mean the whole system powers on a minute after the TV or the sound is produced a minute after the oicture on the TV? If so, is there a delay or sync issues between the picture and sound or they're sync when the sound eventually comes on?
Also, do you have the control for HDMI settings or BRAVIA Sync -as Sony calls it- enabled? If so, could you try to disable this option and test the performance of the system? You can also try testing the connection with a different HDMI cable if possible.
In the meantime, you can use this link to make sure your home cinema system is running the latest firmware version.
Let us know the outcome.
Regards,
Batee5
