I am at the end of my tether now and about to through everything through the window and need help
I have a str-ks100 surround sound but will only play in 2ch. Now I can get sound from the rear speakers but not a full surround sound more the back are playing the same as front 2. I have tried optical cable, normally used HDmi as I have multiple inputs. Change all settings calibrated the speakers you name it I have tried it. What am I doing wrong
Hi there,
Hopefully a community member can help.
Best wishes,
M
Hello @Atreyu218,
which type of signal are you feeding the system?
If you want sourround, you need to feed a sourround signal into it, otherwise you either get 2.1 sound or "copy" that 2.1 sound to the rear speakers as well.
- Nic
Currently using virgin media tivo v6 box, ps4, Google chrome cast ultra as my 3 main inputs all support dolby surround sound
Hi Atreyu218 ,
I couldn't find the model on the Sony UK website at all . Are you sure it's STR-KS100 ?
Cheers,
The_Black_Rose
