EXTERNAL HARD DRIVE
WeTheStrange
EXTERNAL HARD DRIVE
I recently purchased a Sony SVRHDT500B hdd player. Can anyone recommend a suitable external hard drive to use with this particular unit?
Anonymous
Hi there
I have a 2TB WD Elements HDD connected to my HDT500 PVR Recorder. It works brilliantly straight out of the box. It does take about 2 minutes on 'bootup' of the PVR for it to detect. I tried a 3TB HDD of the same kind, and had problems.
http://www.amazon.co.uk/Elements-External-Desktop-Hard-Drive/dp/B003IPC21Y
Cheers.
3 REPLIES 3
Anonymous
Hi there
Cheers.
WeTheStrange
Ok thankyou.
WD AVTV
HOW DO I GET THIS TO WORK WITH MY  SONY RECORDER. SVRHDT500B ? thank you
