Hi
Could you help. I have a CT260 Sound Bar and have just bought a Samsung Smart Tv. I have it connected via the optical cable and all settings are correct but I have no sound. Sony Support said it was not compatible.
Browny59
Hi there
I have moved you post to the relevent section.
You state that all settings are correct, however can you please confirm the following settings (as you may have missed one).
Note: There are no settings on the CT260 to change other than the input source. The CT260 should work fine on a Samsung TV, assuming its connected correctly and TV settings changed accordingly.
Thanks for the reply.
I will check the optical cable to make sure it clicks, other than that it is all correct. The green light is on the sub woofer. I did speak with Samsung who went through all the correct settings with me.
I had it connected to a Samsung TV before I bought this one and it was fine.
Browny
Hi
Tried everything you suggested.... Still nothing
Damn.
Ok, lets think about this logically (also helps me think).
I can only think of 2 conclusions on this
Other than that, I am out of ideas at this stage to be honest.
Yes Damm
I will check the cable to see if its broken but apart from that I am stumped at this stage. Thanks for your help anyway..
I will keep trying.....
Please let us know how you get on anyhow as Im definately interested to know what the issue is.
Hi there
I am glad you have managed to resolve it. Must be a relief for you ! Thanks for posting back, always like hearing how things turn out.
