BDV-N790W
SerdanGM
BDV-N790W
When I try to use VTuner I get a message with "Reference code 51"
I also very often has problem to connect to Netflix, often solved by restart the device but not always ;-(
//Anders
3 REPLIES 3
Anonymous
Hi there
Your problems seem to be internet/network related.  What speed is your internet connection?  Is the N790W connected wirelessly or wired up with an ethernet cable (if wireless, try using a cable instead)
Are you on the latest firmware - best to check?
Have you tried a factory reset?
Just a couple of pointers
If nothing works, more information is required.
SerdanGM
My internet speed is 100/10 so I think it is ok and it is wirelessly I havn't tried wire but will try it but it has worked before and the suddenly it don't.
Latest firmware? on BDV-N790W?
I tried factory reset and it didn't help
//Anders
SerdanGM
I connected my device with a cable and the problem is still the same.
VTurner always shows errorcode 51 and Netflix works sometimes and sometome no, what to do?
