Hi there
You cant just connect the speakers up to the TV or something similar. You need some type of base unit which acts as an amplifier/power unit as well as software to support different types of audio (ie DTS, DD, etc).
As an opinion, I would pull back that base unit from the N590 and put it back in the lounge room, and then purchase a Smart Bluray Player such as the BDP-S1200. Approx £60
Alternatively, I understand that Netflix is available on a device called Chromecast - Approx £30
Thanks for your help, it makes sense. I was hoping to not have to purchase an additional device that does the same job as an existing.
The N590 was given to me so it wasn’t a choice purchase on my part otherwise I would have gone for a more suitable set up.
