Hi there
Firstly, you need to connect a HDMI Cable from the TV's HDMI 1 (ARC) port to the N7200W (HDMI-OUT-ARC). You cannot use other HDMI ports on the TV - only the one specified as ARC. Also ensure that your HDMI cables have ARC functionality. HDMI version 1.4.
Ensure that Bravia Sync is switched on, on the TV and N7200W (should be by default). And then set TV Speakers to Audio System.
Ensure that the N7200W is also switched ON.
If you can confirm that and it still doesnt work - please reply back.
Hi there
Your most welcome - Glad your now up and running
