All one on surround sound systems
djknight88
Hello.
I have been trying to find a Sony surround sound all in one system to replace my current Sony one, my current one has 3 hdmi in, I would like really to have more than 3 but definitely no less. I can't seem to find any other systems with this, mostly they seem to have only 1 out and none in, can any one point me in the direction of a suitable system if possible.
23 REPLIES 23
djknight88
Now this the the confusing thing, have tried a few more things.
On ps3 if I have sound set to.
Dolby digital 5.1
Linear PCM 2 44.1 and 48
I get 5.1 on games but not blu rays if I use what I used to have on when ps3 was directly in the AV which is dts 5.1 Dolby 5.1 dts hd etc I get 2.0 on games and blu rays
Anonymous
Unknown about games, but blurays are always good to test.
In the PS3 settings, try changing the Audio Output to Linear PCM (or if already set, try bitstream)
http://manuals.playstation.net/document/en/ps3/current/settings/bdsettings.html#1470
Also in the PS3 settings, try unticking all 2channel settings, and only leave 5.1 LPCM
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
djknight88
I changed to bitstream but got no sound at all on the blu ray film, ps3 won't let me de-select linear PCM 2.0.
So strange if I only have Dolby digital 5.1 and the forced 2.0 linear selected it works but only on games not bd films.
Anonymous
It should be set to Linear PCM in the HDMI audio output settings.  Basically the PS3 should be doing the decoding of the Audio.  The reason why you got no sound is because the HT-SS100 cannot decode the audio.
If you look at the specs of the HT-SS100 under decoding format
http://www.sony.co.uk/support/en/product/HT-SS100/specifications
For blurays, are you able to set it to DTS, and not DTS-HD?  Maybe try a DVD instead (thats 5.1)
It all seems rather weird hey.
djknight88
So strange when ps3 was plugged into the AV it all worked fine, I just couldn't use 3d content and was running out of hdmi spaces for surround. Everything seems so confusing and complicated.
djknight88
I have added just dts 5.1, but still 2.0 on both bd and dvd
Anonymous
Ok, what about another way
PS3 > HDMI > TV
PS3 > Opical > HT-SS100
Change output settings accordingly
If it works, would allow you to watch 3D movies on the TV, and output audio via the HT-SS100
djknight88
Seems to work on games and bd's at 5.1 now. Thanks ever so much, it's a shame it didn't work the other way would of gained a few more hdmi's. But this is better than not at all. Thanks a lot for all your help, sorry to trouble you.
Do you have any suggestions of other ways to gain more hdmi's or a better surround sound perhaps
Maybe my tv can only do Dolby 5.1 and not this dts one.
Anonymous
Im glad its working at least.  Yes the whole intention was for you to watch 3D AND gain HDMI spaces (1 extra anyhow), whilst still outputting surround sound.
I guess for extra HDMI ports, you could try one of these to connect to the HT-SS100:
www.amazon.co.uk/Duronic-HDS3-Switch-output-Switcher/dp/B0020426AG/
Ive not seen them in action, so cannot really comment on their effectiveness - but at the cost of 3 pints (ish) its not too expensive.
djknight88
Thanks again much appreciated.
I was looking at the other surround sound options, where you buy everything separately, down bit is it's more money which I could save up if it's worth it but also I wouldn't have any idea what speakers to go with what AV receivers with om's and watts etc, so confusing.
Like this one http://www.sony.co.uk/product/hcs-home-cinema-receiver/str-dn840
