sonny_lofthus
Sony Shake-33
Hello, i own sony shake-33, but without speakers (i own only player), so i need to buy new speakers, my question... can i order passive speakers with 400w rms? or active speakers? ... do i need to buy speakers with 2200 rms? (its written on the box) ... thanks.
i own only player, not speakersi own only player, not speakersback side of playerback side of player
5 REPLIES 5
Pascale_F
Moderator
Hi Sonny,
Welcome to the community.
Since the connectors for the SHAKE-33 are very special, you’ll need to have the original speakers. Check out EET here for some replacement speakers and let us know how you get on.
Thanks,
Pascale
sonny_lofthus
thanks for your answer, i bought this player without speakers and i cant buy speakers alone, i can buy passive speakers for good price with cinch connectors.... so.. what now? :grin:
IamNic
Does it work, if you connect the speakers you bought to the "Party Chain" chinch output?
- Nic
kan man få forlænger kabler/ledninger til højtalerne
hvor
